TPI L98 engine swap air mangement system
Old Jun 24, 2010 | 02:28 AM
troyskibert's Avatar
Default TPI L98 engine swap air mangement system
troyskibert here and I am the newie on this forum. I am doing a 5.7L TPI engine swap into my '87 Landcrusier. The 5.7L TPI came out of an '85 Corvette. I can't believe I am loosing 200 lbs. in this conversion and gaining 100 horse power and around 50 ft. lbs. of torque! We have emissions to pass here in CA and I am wondering if this TPI engine has a seperate air switching valve and diverter valve. I bought a 1985 switching valve with one wire connector and three ports for hoses. I know the top port goes to the air cleaner TB via the hardline. Where do the other two go? they are in the middle side and straight out the bottom...one is for cat and the other? I have also got a diverter valve from a later model TPI which connects directly to the air pump, and exit ports go to the exhaust ports and cat and lastly the diverter port...which diverts through the silencer into the atmosphere. This diverter valve I have has two wire connectors, one top and bottom. Is this diverter valve I have a combo of air switching/diverter valves or do I need this and also the '85 switching valve I just bought or do I just hook up the diverter port to the air cleaner TB instead of through the silencer? I am trying to finishing the ecm wiring and see that there is one wire for "divert" and one for "switching". Is the top connector the "divert" wire and the bottom the "switching" wire. It is really hard to find anyone who knows this older TPI stuff. I posted on the Third Generation TPI fourm website and have not got a reply yet. Can someone out there help me please 'cause I want to get on the road and !!!!!!!!!
Old Jun 24, 2010 | 09:17 AM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
Here is the site I used for my TPI conversion a few years ago. it has alot of good information that you may find useful.
http://chevythunder.com/
Old Jun 25, 2010 | 12:09 PM
Cool Thanks for website info
thanks, i learned a bunch from this website given to me! Any other comments or suggestions are much apreciated!
Old Jul 1, 2010 | 02:16 AM
greenarrow's Avatar
September 2009 ROTM
Welcome to the forum.
mgd1006
May 3, 2014 10:11 AM
3800_seriesII
Aug 14, 2012 07:24 AM
zelda782
Jan 12, 2012 04:13 AM
roman36
2010+ V6 Tech
Jul 22, 2011 03:50 PM
jrb78
82-92 V8 Tech
11
Dec 16, 2007 07:05 PM
