Need Advise
Old Jan 12, 2007 | 04:56 PM
Bowlergt's Avatar
Default Need Advise
I just bought a 1981 camaro with a 305 in it, I will late be putting a 350 in it but the carb that is on it now doesnt have any connections for the choke and the throttle linkage is held on with a zip tie. Was looking fo suggestions on a carb for it that would be a good transfer to a 350 later. Also looking for something a little cheaper right now. On a 1981 would I need an electric or manual choke and if electric where would the wires be to hook t hat up.
Old Jan 14, 2007 | 05:19 AM
95slvrZ28's Avatar
Default RE: Need Advise
I suggest Edelbrock carbs, probably the 650 CFM. It'll give good street performance with faster throttle response than if you got a 700+ CFM carb. Holley makes good carbs too, but they work really good in 2 positions, Idle and WOT. I'm not sure what intake manifold your camaro has on it, but you need to make sure if you have a Quadrajet carb right now, you get an intake manifold that has the right flange(I believe it's square, but if you search at summitracing.com you'll be able to find it).
Old Jan 14, 2007 | 09:09 AM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
The electronic choke should be wired to a +12 volt constant that is activated by the ignition switch the negative side gets grounded. I have an edelbrock 600 on my car and it works fine.
glensilver
Oct 3, 2010 08:26 AM
SixShooterCamaro
Jul 27, 2009 01:38 AM
kdm212
May 26, 2009 09:00 PM
CamaroSS1980
82-92 V8 Tech
Jul 10, 2008 11:54 PM
FunkyColdMedina
Jan 29, 2007 03:04 AM
