How would i gut my Cat. ????
Old Feb 4, 2008 | 04:03 PM
98Z28ImportSlayer's Avatar
Default How would i gut my Cat. ????
I want to gut my cat. on my 98 camaro z28 how would i do this ? i dont have to worry about emissions so yippie
Old Feb 4, 2008 | 06:54 PM
95slvrZ28's Avatar
Default RE: How would i gut my Cat. ????
Well, to successfully gut a cat I'd get a sharp knife, or if you want to be scientific about it, a scalpel. Now, the best thing to do is to start at the base of the neck at the top of the sternum, hold the cat tightly and make a cut down one side of the sternum. Once you get to the Zyphoid Process you can continue to cut down the ventral surface of the cat, through the abdominal muscles all the way to the pelvis. At this point I'd suggest breaking the rips away from the side of the sternum that you cut down and break them along the side of the cat as well. If you make two horizontal cuts, one going from shoulder to shoulder and the other right below the lower abdominal muscles you should be able to open the cat up fairly easily. From this point you may proceed to remove the intestines and other internal organs.
Or...you can pull the cat back off your car, take a metal pipe and ram out/clean out all the honeycomb...
Old Feb 4, 2008 | 07:13 PM
bluovlh8er's Avatar
Default meeeeeowwww
haha i love these treads.
Old Feb 4, 2008 | 08:20 PM
buckfever's Avatar
Default RE: meeeeeowwww
well after you gut it you might wanna concentrate on beefing up your rear end, transmission, clutch if you have a manual, wiht the unbelievable power gutting your cat will give you.
Old Feb 4, 2008 | 08:46 PM
yes that it is so true! that 2hp i gain may just win me a race against a Z06 ???? lmao im gutting it so it will be alittle bit louder dont really care about the 2hp gainbut hey free hp for alittle hard work yippie. Oh yeah im not sure about 93-97 camaros but on my 98 the Cat is welded on it ..... its a ***** i know
Old Feb 4, 2008 | 09:05 PM
95slvrZ28's Avatar
ORIGINAL: bluovlh8er
Really man, do you have to post ***** and change the names of threads all at the same time!
Old Feb 4, 2008 | 09:40 PM
????? sorry im completly lost im just trying to find out how to gut my cat. i tried using a long metal screaw driver with a hammer and it did alittle then i hammered the cat. and it did alittle but theres still 75 percent left so im open to any suggestions that would work.
Old Feb 4, 2008 | 10:12 PM
BigNic's Avatar
4' 11" 117 lbs of fury!
get a long, thin metal object with some bend to it then just whirl it around inside the car and tear down the meshing ......
Old Feb 5, 2008 | 02:07 PM
Alright, thanks bignic im going to lowe's right now to buy a metal rod
Old Feb 5, 2008 | 03:24 PM
bluovlh8er's Avatar
i really love you guys
