Header wrap.
Old Nov 8, 2006 | 11:58 AM
T10wheels's Avatar
Default Header wrap.
I've heard that it's not good to wrap ceramic headers, but will it have an effect on painted ones?
Old Nov 8, 2006 | 03:58 PM
bowtieguy's Avatar
July 2009 ROTM
Default RE: Header wrap.
before anybody gets offended,this is what i've heard.when you wrap the headers,they are supposed to flow better because of the heat that is trapped inside the header because of the wrap.the wrap also makes it easier to change plugs because of less heat.i've also heard that the wrap holds moisture and tends to cause rust.it takes alot of the heat out of the engine compartment.i would do it,so what if they rust out prematurely.i think the gains out weigh the losses.jmo
Old Nov 8, 2006 | 04:37 PM
T10wheels's Avatar
What about that metal tape? same thing or would that work better?
Old Nov 8, 2006 | 06:19 PM
blackz87's Avatar
Header wrap on street driven car will result in moisture build up rusting the headers, On a strip only car no problems and are advantvage holding heat down.[sm=gears.gif]
jpkz94
Dec 16, 2010 05:07 PM
nine-six-zee28
Nov 28, 2010 07:03 PM
mattz28red
Feb 7, 2008 09:03 PM
mattvogt
Apr 28, 2006 12:27 PM
