Exhaust
Old Jul 22, 2006 | 01:27 AM
azzkikn z28's Avatar
Default Exhaust
wat is a good exhaust for a third generation camaro's i am lookin for a deep sound to it... THANX
Old Jul 22, 2006 | 02:15 AM
TimmyTheWop89's Avatar
Default RE: Exhaust
Ill tell you what i did i guess. i also have a 3rd gen. first of all i bought headmans long tubes. put them in yourself to save money. to do that, i had to lift the motor, along with dimpling the header to fit near the starter, i took out the brake booster and master cylinder, and also the wiper motor. to lift the motor jsut put a jack under the oil pan with a piece of plywood in between. that should pretty much do it unless you have AC which would take some more finageling. putting the heads in yourself will save you about 300 dollars. for mufflers i chose 2 moroso spiral flows and an x-pipe, but dynomax came out with an ultra flow that is a muffler and x-pipe combined, if i had known i would of got that instead to save money. i had a custom exhaust shop run true dual 2.5 inch exhaust, both pipes running down one side. i bought the mufflers and headers, and installed the headers, and it cost me 800 dollars with mandrel bent pipes. sounds unbelievable and oit restriction free. if you dont want to go all out, you can get borla catback or magnaflow cat back, or jsut throw a flowmaster on there.
Old Jul 22, 2006 | 04:37 PM
86Stang's Avatar
Default RE: Exhaust
Well i think flowmaster's sounds good on camaro's but 2 b cooler...... GET A MUSTANG!!!!!!!!!!!!!! hahahaha kurt
Old Jul 22, 2006 | 07:11 PM
Default RE: Exhaust
azzn, when purchasing a mustang, you have be careful. first of all the distributors are in the wrong spot. most of the time its not worth the money to get it put in the rear where it supposed to be lol.
Old Jul 24, 2006 | 11:10 PM
86Stang's Avatar
Default RE: Exhaust
y is that?
Old Jul 26, 2006 | 01:05 AM
Default RE: Exhaust
Probably easier to turn the Stang engine front to back, but then the water pump will be in the wrong place.
Old Jul 27, 2006 | 12:06 AM
Default RE: Exhaust
yea see you get a ford and you jsut get in a big mess.
scottlt194
May 14, 2009 08:27 PM
famlyguy18
May 6, 2009 05:26 PM
dbess23
Sep 17, 2007 02:02 AM
javione
Feb 16, 2007 02:27 AM
jhop16
Jan 9, 2007 11:21 AM
