Chrome Exhaust Tips?
Old Sep 18, 2009 | 07:44 AM
rockinroller's Avatar
Default Chrome Exhaust Tips?
My '97 Z28 has dual exhaust tips that "bend downward" at the rear bumper. Is there an aftermarket chrome tip that I can attach to each pipe, that would ultimately appear to be "straight out" from a rear appearance perspective (i.e. if I simply put a chrome extension on the existing pipe, it would head downward)? Thanks.
paul
detroit area
Old Sep 19, 2009 | 05:09 PM
02StanGT's Avatar
Is your exhaust stock or aftermarket?
Old Sep 20, 2009 | 05:48 AM
Aftermarket (Flowmaster--3.5" OD pipe size).
Old Sep 20, 2009 | 12:25 PM
02StanGT's Avatar
the whole pipe from the muffler angles down? or is it just the tip? either one, an exhaust shop should be able to fix you up for cheap. unless you know how to weld yourself.
Old Sep 21, 2009 | 06:15 AM
The pipe is straight out of the muffler, then bends downward about 15 degrees at the very end. I was hoping to get a set of those chrome tips that have set screws so that I could install them myself.
Old Sep 27, 2009 | 12:38 AM
ohgrfreak's Avatar
NOOOOOOOOO!!!! Please don't do the Pep Boys/Walmart thing and get the set-screw tips. A) they'll still point down, and B) they'll look like garbage after a while and C) they will most likely fall off on their own at some point in time.
Go to any muffler shop, pick out two stainless steel tips (SS won't corrode like chrome plated bronze or zinc or whatever is underneath the cheapies) by Magnaflow or whoever and have the shop A) straigten your pipes and B) weld those puppies up. They'll charge you next to nothing for the actual welding so price mainly depends on brand and quality of the tip.
Old Sep 27, 2009 | 06:13 AM
Thanks. Unfortunately I already ordered a pair of 9" straight chrome extensions with a "set screw" online but I intend to clamp the chromes on to the exhaust pipes after cutting them (the exhaust pipes) at the point where they stop being straight out and start bending down. This will leave my finished chrome tip just barely under the rear bumper fascia. Thanks to all of you for your well-thought comments.
Old Sep 28, 2009 | 09:14 AM
ohgrfreak's Avatar
If they're good enough quality, hopefully they'll last a while and look good, toss up some pics when you've got em on!
pondo1000
Oct 17, 2011 11:36 AM
ricer_killaZ28
Aug 20, 2009 07:24 AM
famlyguy18
May 6, 2009 05:26 PM
dorn4ever
May 3, 2008 03:01 PM
Celticsfan
Jul 26, 2006 02:05 AM
