95 z28 header gasket ?
Old Apr 20, 2008 | 04:46 PM
redreffitt's Avatar
Default 95 z28 header gasket ?
I have a 95 z28 and I have decided to go with the 1 3/4" kooks long tube headers and ORY. Was wondering what type of header gaskets I need to get and if the stage 8 bolts are the best to use? Also curious if ground clearance is going to be a problem when combined with eibach pro-kit lowering springs? Thanks for your help!
Old Apr 21, 2008 | 10:09 AM
95slvrZ28's Avatar
Default RE: 95 z28 header gasket ?
The Kooks headers come with gaskets, although if you're not very persistant with tightenging your header bolts you'll get a massive exhaust leak within a couple of months (speaking from experience here!). After I charred a hole through the gaskets that Kooks provides I got a set of Mr. Gasket Premium header gaskets and I haven't had any issues yet. The Premium line are made out of a substance called Graphoil which is extremely heat resistant because it's primarily composed of graphite. As far as ground clearance, Kooks headers have the best fit/ground clearance of any LT1 header. You're going to lose about 1-1.5" of ground clearance over stock, as long as you're careful you shouldn't have too many issues.
Chevy101
May 18, 2011 06:54 PM
badlandsusa
May 3, 2010 10:00 AM
Kushal_2
Oct 12, 2008 08:04 AM
microkid
May 15, 2007 05:16 PM
350rs
May 9, 2007 01:30 AM
