Question on 2018 Camaro SS Electric Exhaust
Old Nov 15, 2023 | 05:56 AM
Markstp's Avatar
Default Question on 2018 Camaro SS Electric Exhaust
Hey folks,
I just bought my first Camaro, and love the car, previously a Corvette owner. My question is, the exhaust is very loud, which I like and my wife does not. I believe the exhaust has the electric open/close feature, but I cannot seem to locate how to operate it. Can anybody guide me on this?
Thanks very much!
Mark
Old Nov 15, 2023 | 06:25 AM
I do not own one but I was under the impression is the exhaust sound was tired to the mode you are in. Track/Sport mode loud, Tour mode quiet.
That assumes the car still has the stock exhaust. If your BCM logs keys (like seat position) you can save a default mode.
Old Nov 15, 2023 | 06:37 AM
Markstp's Avatar
The exhaust sound doesn't change from mode to mode. I'm pretty certain it has the electric gates that can be opened ore closed. I believe it's in the settings menu somewhere, I just need to find it.
Old Nov 15, 2023 | 07:59 AM
Well if you disconnect the battery and press the brake it will reset all saved parameter back to factory configuration. The modes should work then. I looked up the mode options and right under tour it says quiet exhaust.
You could have a issue with the the exhaust, relays or someone swapped out to a performance exhaust. Of course the PCM could have been reprogrammed but I can not imagine changing the tour mode unless an aftermarket cam was installed.
Old Nov 15, 2023 | 08:57 AM
Markstp's Avatar
Thanks for the feedback, I'll give that a try and let you know.
Old Nov 22, 2023 | 01:20 PM
Kent A's Avatar
Talking Exhaust noise
I just installed Rotofab and Magna-flow Axle back kit on my '23 LT-1 - no variable exhaust system.
However, it can be ferociously loud depending on the position of your right foot
I bought my other half a set of Bose noise cancelling earbuds.
Now it's all quiet on the Western Front.
out4lox
Dec 2, 2020 09:16 AM
tazinhawaii
Jul 21, 2019 01:53 PM
34ford454
Mar 12, 2018 04:13 PM
34ford454
Mar 12, 2018 04:12 PM
sebi1990
Oct 3, 2010 02:16 PM
