Weird starting issue...
Old 03-28-2009 | 11:30 PM
greenarrow's Avatar
September 2009 ROTM
Ok, then I would say it's the ignition then. Sounds like it's crossing over a bit into start when it's in run. Replace that and you should be good. When in run, there's not enough power getting crossed over to start it, so the selonoid is engageing, but the starter is not getting power. Haven't heard of that before, but I don't doubt you at all.
Old 03-29-2009 | 01:29 AM
PAzYearazzUP's Avatar
Now you need to set a timing light on the rear cylinder(s) so you can hold the gun trigger and see if you have spark. It should run with spark, fuel and compression.
You are missing one of the 3 if it does not start is which one?
Old 03-29-2009 | 12:11 PM
stellar's Avatar
fuel pump or fuel pump relay possibly. cranks but won't run sometimes. Sounds like fuel problem.
Old 03-30-2009 | 09:52 AM
APSASM's Avatar
The starter motor on these cars get hot because of their location. If you have a lot of miles on the car it might have been caused by all of that heat. Sounds stupid I know but I had the same problem. Replaced the starter and added a little heat shield. Good to go.
Old 03-30-2009 | 10:38 AM
traumadog's Avatar
This is what I was thinking.
And I'm not sure how heat's involved except as an added wear thing, because the car's been cold (<40* soak) when it happens. And I know it's not a battery issue, because it started once after about 2 minutes of unsuccessful trying just before.
djsquare1
08-06-2014 08:32 AM
Chris Wood
02-29-2012 03:50 PM
DarlingReject
10-20-2010 10:16 PM
ryan88z
03-09-2009 09:01 PM
jdubs1813
03-18-2007 03:04 PM
Quick Reply: Weird starting issue...
