water pump issues
Old Sep 9, 2006 | 01:33 AM
Saint_Ali's Avatar
Default water pump issues
i recently installed a new water pump back in july and now it is starting to leak again, but its coming from the mounting bolts, i have tightened them and it has helped but it still continues to leak from the bolts, any suggestions ?
Old Sep 9, 2006 | 01:35 PM
94Z28SHAKER's Avatar
Default RE: water pump issues
put some kind of RTV sealant around the bolt threads, that will help it seal.
Old Sep 9, 2006 | 10:40 PM
v8chvyguy's Avatar
The silicon may still leak cuase it tends to dry hard. Teflon thread sealant is intended for that use and you may have better luck with that. It can be found next to the silicon at your parts house.
Old Sep 10, 2006 | 12:24 AM
MadMikeZ28's Avatar
The black permatex works great on threads. When doing a wet clutch on motorcycles and dealers never have a gasket in stock that stuff worked exelent on the side covers.
Old Sep 14, 2006 | 05:01 PM
1969 SS's Avatar
they have sealants made specifically for that purpose
Old Sep 15, 2006 | 03:16 PM
Blade's Avatar
June 2007 ROTM
did u check the gaskets?
Old Sep 15, 2006 | 03:48 PM
Saint_Ali's Avatar
no its not leaking from the gaskets, its from the two bolts on the front
Old Sep 15, 2006 | 08:14 PM
Blade's Avatar
June 2007 ROTM
copy! did u try adding silicon around the threads?
Old Sep 17, 2006 | 08:50 PM
1969 SS's Avatar
again, you don't want to use silicon. you want to buy a Permatex RTV used for the proper application. you then want to make sure that the surfaces are cleaned of any residual coolant so they don't affect the way the sealant sits on the surfaces. it is also very common for the coolant to leak out along the bolts it you don't put some on the threads. it is sort of the same way that it can happen with BB Chevy head bolts
take your time, do a clean and thouough job and you should never have anymore problems
Old Sep 17, 2006 | 10:42 PM
Saint_Ali's Avatar
ok thanks i appreciate it, i will keep you posted
