vacum lines????
Old Mar 28, 2006 | 01:37 PM
burntrack's Avatar
Default vacum lines????
i have a 350 out of a 82 chevy truck and i want to take off the polution pump- does ne1 know what vac. lines i need to rum and where the go to and come from? no need for emissions so i dont need the polution pump. thanx guys! p.s a diagram could also help.
Old Mar 28, 2006 | 06:37 PM
xc|bandit's Avatar
Default RE: vacum lines????
All you need is 1 vac line for your distributer and 1 for heater select.you can cap the rest.
Old Mar 28, 2006 | 07:55 PM
bowtieguy's Avatar
July 2009 ROTM
need one for the transmission also if your running a automatic
Old Mar 28, 2006 | 09:57 PM
xc|bandit's Avatar
that and your brake booster
Old Mar 30, 2006 | 11:38 AM
burntrack's Avatar
what is the heater select and do i need the vac. canister in the front of the car(factory 1) if i have a crane cam vac. canister. i need to know what ports go to where or does it matter?
Old Mar 31, 2006 | 12:19 AM
xc|bandit's Avatar
you should have a vacuum line that goes to the fire wall...its for you heater/ac controls
ozzies 68
May 7, 2015 08:06 PM
riss1978z28
Mar 5, 2012 05:45 AM
95camz28
Nov 13, 2007 04:44 PM
ridinbikes247
Jan 14, 2007 02:21 AM
motor tec
Nov 7, 2006 07:42 PM
