vacum lines????
i have a 350 out of a 82 chevy truck and i want to take off the polution pump- does ne1 know what vac. lines i need to rum and where the go to and come from? no need for emissions so i dont need the polution pump. thanx guys! p.s a diagram could also help.
RE: vacum lines????
All you need is 1 vac line for your distributer and 1 for heater select.you can cap the rest.
RE: vacum lines????
need one for the transmission also if your running a automatic
RE: vacum lines????
that and your brake booster :)
RE: vacum lines????
what is the heater select and do i need the vac. canister in the front of the car(factory 1) if i have a crane cam vac. canister. i need to know what ports go to where or does it matter?
RE: vacum lines????
you should have a vacuum line that goes to the fire wall...its for you heater/ac controls
