upgrading to 17 inch rims
Old Jan 31, 2008 | 03:43 PM
ollie2009's Avatar
Default upgrading to 17 inch rims
I want to go to 17 inch rims in my Camaro but will I have to mess with the speedometer? What do I have to do to make it work?
Old Jan 31, 2008 | 04:29 PM
blackz87's Avatar
Default RE: upgrading to 17 inch rims
Nothing, if you just go up +1. For example:If you go from 16'" wheels & 245/50 tires to17" wheels and 245/45/17 tires requires no change in the speedometer. The wheel & tire height did not change.
Old Jan 31, 2008 | 04:30 PM
bluovlh8er's Avatar
naw on my 95 i just put 17's on it and didnt notice anything......
Old Jan 31, 2008 | 04:58 PM
MadMikeZ28's Avatar
Just use a lower profile tire that matches the diameter of tire you have now.
http://www.1010tires.com/TireSizeCalculator.asp
Type in your tire size now and the size you want and any optional sizes and it will show all the different measurments and a general idea of what your speedo will read with the different sizes.
Old Jan 31, 2008 | 07:32 PM
maroman209's Avatar
i went from stock rims to 18 inch.. didnt see a diff.. tire size is 245/45/18
Old Jan 31, 2008 | 07:49 PM
95slvrZ28's Avatar
To keep the same speedo ratio with a 17" wheel you need to run a 275/40/17, of course the aspect ratio varies depending on how wide the tire is, but if you're getting aftermarket wheels you should probably go with a 17X9.5.
Old Feb 4, 2008 | 02:33 PM
ollie2009's Avatar
Thanks alot guys. I'm getting some black vette rims so I needed to know.
Bmack
Jul 17, 2010 09:08 AM
Lawhead09
Apr 5, 2010 10:33 AM
Lawhead09
Apr 4, 2010 01:28 PM
ninetysixyenko
Jun 29, 2007 02:57 PM
monops87
Mar 12, 2006 11:34 PM
