unaccurate tachometer
Old Feb 27, 2009 | 07:53 PM
91camarorsman's Avatar
Default unaccurate tachometer
i recently obtained my first car, a 91 rs camaro , the tach is wayyyyyyy messed up though, it says im doin 7000 when im really at 1500, i have checked all fuses and that so far hasn't helped, any advice would be greatly appreciated
Old Feb 27, 2009 | 09:25 PM
zaxroom's Avatar
You need a new tach cable, it probably got wet or something I can't tell you exactly but it's most likely broken. It runs from behind the gauge to the distributor your better off just getting a new one
Old Feb 27, 2009 | 10:24 PM
Assuming your tach was not taken from a pre-80's corvette you do not have a tach cable.
It could be a bad ground or a loose connection. A electronic tach is a very simple device. All it does is counts how many times the coil fires. Its hooked to the negative side of the coil. It knows 4 fires equals 1 RPM. So something is wrong with the connection from the coil to the tach or the tach itself.
Opps in your case its 3 fires equals 1 RPM
Old Feb 28, 2009 | 10:01 AM
zaxroom's Avatar
How silly of me I didn't even remember its not a cable any more. Good call!
Old Feb 28, 2009 | 02:10 PM
Your tachometer problem is very common among the 1990-92 Camaros. Even my 91 read double, I just compensated. The more people you talk to, and read about, will show you that a tach in these models that reads accurately, is a rarity. The issue is with a bad circuit board behind the tach in the dash cluster. Give this a read:
http://www.thirdgen.org/techboard/el...eter-fix.html?
Old Mar 1, 2009 | 03:42 PM
thanks man, that article really helped, im glad its not just my car
McGnrAcDcfan227
Oct 29, 2009 08:44 PM
71CamaroZ28
Apr 24, 2009 11:12 PM
1979RS
Aug 17, 2008 12:10 PM
milferd3@yahoo.com
Jan 19, 2008 07:54 PM
burnout
Jan 9, 2007 06:31 PM
