ugh idk what else to do...
Old May 28, 2007 | 07:32 PM
jhop16's Avatar
Default ugh idk what else to do...
my car stutters wickid bad when i step on the gas past half ... today i put 250 dollars into it, replaceing coils, plugs, wires,fuel filter, and an oil change... i got excited cuz i went to drive it and it wasnt sputtering till 5 minutes later i went to take off and sputter away it went.... what else could be wrong with my poor 3.8L
Old May 28, 2007 | 09:30 PM
badinfluenceRS's Avatar
Default RE: ugh idk what else to do...
fuel injector (s) need to be cleaned, or one may be clogged or bad
Old May 29, 2007 | 12:50 PM
jhop16's Avatar
i've used fuel injector cleaner, how else would i clean it
Old May 29, 2007 | 01:13 PM
1969 SS's Avatar
you don't say if the car was running good before you did this, so I'll just assume it was (hate assuming). are you 100% sure you put your plug wires on right?
did you put your fuel filter on backwards?
Old May 30, 2007 | 09:31 AM
jhop16's Avatar
it was running like **** before i did any of that, thats why i replaced all that stuff, to try and fix it, it only misfires when i step on the gas passed half ....=/
Old May 30, 2007 | 09:43 AM
2lucke4u's Avatar
I had a problem similar to tat in my other camaro and I replaced the coil and it worked finr.
Old May 30, 2007 | 03:23 PM
Nope, most of that cheap-o cleaner wont work, you can get the injectors cleaned at a shop
Old May 30, 2007 | 09:00 PM
jhop16's Avatar
yeah i got new coils before when i had the problem,
thnx bad, how much you think that'd run me?
Old May 30, 2007 | 09:28 PM
I bought my car w/ a bad fuel injector (why it was so cheap) and I just paid a shop like $250-300 to fix it...
You could DIY for cheaper
Also, if it's not just a bad or a couple bad fuel injectors, you can get them all cleaned at a shop, not sure of the rates for that service tho
