torque converter ?
Old Mar 12, 2010 | 08:06 AM
freaky's Avatar
Default torque converter ?
lock up or non lock up ?
Old Mar 12, 2010 | 08:40 AM
blackz87's Avatar
Lock-up on a daily driver...
Old Mar 12, 2010 | 08:42 AM
freaky's Avatar
whats the difference in them ?
Old Mar 12, 2010 | 08:52 AM
blackz87's Avatar
Google it..it will give you a education.
Old Mar 12, 2010 | 11:53 AM
GMDCAMARO's Avatar
Old Mar 12, 2010 | 07:15 PM
microkid's Avatar
March 2011 ROTM
Technical User
lock up will reduce trans temps and increase fuel economy
Old Mar 12, 2010 | 09:29 PM
freaky's Avatar
i'm hoping it's the torque converter .under wot the car revs quick an doesn't pick up any speed like a clutch slipping in a manuel tranny car .
any thoughts ?
Old Mar 13, 2010 | 09:18 AM
An automatic has a clutch pack that can slip when worn, just like a worn manual tranny clutch. Does it slip off the line, or when in passing gear, or both? Does it make a difference depending on what gear it's in?
Old Mar 13, 2010 | 11:58 AM
freaky's Avatar
more so from a roll but it still slips coming off the line
Old Mar 13, 2010 | 12:28 PM
How many miles on the trans?
Start with the easy stuff first. Is your fluid at the proper level? Is your TV cable adjusted correctly: http://www.73-87.com/7387garage/drivetrain/tvcable.htm
Does the fluid on the dipstick smell/look burned? That would be a sign of the clutches possibly slipping. Could also be something wrong with the valve body. Have you checked for any error codes?
jrgearhead
Jan 24, 2012 01:25 AM
tscw96
Dec 27, 2011 09:54 AM
DeathProof
Jul 29, 2011 03:55 PM
samtron
May 15, 2009 09:07 AM
microkid
Jan 15, 2007 06:25 PM
