Tach troubleshoot
RE: Tach troubleshoot
I had never gotten around to hooking the filter up on my 84 and the factoyr tach worked fine. Its just noise reduction. Check your wires. Power, ground and a signal off the negative of the coil. Should be a white wire usualy.
[X(] you should have an hei ignition unless youve decided to go back in time. ill assume the "filter" you speak of is a capaciter and in most cases it either works or it dont and if it dont neither will you get any spark. on hei systems the "tach" terminal is marked on the dist cap. for points you come off the negative side of the coil for a tach signal kurt
ORIGINAL: t9ojetpilot
Stovetop535
10-31-2013 12:41 PM
