Stumble at 2k rpm
Timing is something to check when its adjustable. If you had a scan tool you could see if there was a misfire history and for what cylinder(s). But unfortunatly no one wants to spend good money on one [&o]
So do check plugs and wires and replace the fuel filter just because I know you have not done it. [8D]
ORIGINAL: Alih
rofl nice Mike, can you read my mind next ?
Changing the plugs on a 6 is not bad. Just don't try to get them all from the top.Go from the under side.
