code p0507 idle control system rpm high
Old Oct 26, 2008 | 06:06 PM
Jachin85's Avatar
Default code p0507 idle control system rpm high
How would i go about diagnosing this code. The car has under 50k on it so i doubt it has a dirty tb iac valve or pcv valve, although i have not visually checked to confirm any of this and it runs good enough to where i doubt it has any vacume leaks.
Old Oct 26, 2008 | 08:51 PM
Saint_Ali's Avatar
Default RE: code p0507 idle control system rpm high
have you done anything recently that could have caused this to happen ?
have you cleaned the throttle body recently ?
Old Oct 27, 2008 | 05:39 PM
Jachin85's Avatar
I just bought the car, and i havent done any work on it yet. i know the dealer detailed it before i drove away and the code wasnt on when i test drove it. it also has an aftermarket maf sensor on it, could that possibly be causing the code?
87 camaro z28
Jan 3, 2021 02:01 PM
r00tk1ll
Feb 6, 2015 10:25 PM
fortdub99ss
Nov 1, 2010 04:55 PM
jjcrago05
Aug 5, 2009 04:57 PM
Mustangfighter96Z28
Nov 1, 2007 07:29 PM
