stereo install
Old May 14, 2010 | 12:40 AM
mjlynch71's Avatar
Default stereo install
I will be going to have a CD player installed in my 1969 Camaro. There is no stereo or speakers installed. The holes are cut into the kick panel and do not know if the wiring harness is there. Question, can I just use a wire with a fuse to the battery, and a ground, and the antena, then the speaker wires, this should work. Any info would be great. Thanks, Jerod
Old May 15, 2010 | 07:10 PM
osduck5's Avatar
It should work but if you leave your radio on by mistake, your battery will be dead. I would run the wire to the fuse block on a circuit that turns off when the key is in the off position.
xlowes
Apr 27, 2012 07:29 PM
reaperchild
Apr 23, 2009 08:31 PM
84PRJCT_CR
May 3, 2008 10:15 AM
74Z28
Apr 22, 2008 09:49 PM
th3po1son
Dec 19, 2007 01:03 PM
