speedo driven gears for a T350
Old Jan 16, 2007 | 10:28 AM
tuff308's Avatar
Default speedo driven gears for a T350
Ok, cant seem to get much info in my area of the world so i am going to pick peoples brains here, i am running a T350 box, 3.7:1 diff gears with a 15" rim and a 65 series tyre of which is 21"s all up, what would be thebest driven gear to use to get my speedo working as close as i can.
Does anyone have a chart on all driven gears for a T350, basically need to know what colour gear to suit what final gear ratio.
Thanks in advance, hope you can help.
Old Jan 17, 2007 | 02:03 AM
bowtieguy's Avatar
July 2009 ROTM
Default RE: speedo driven gears for a T350
your top of the line trasmission shops can figure that out for you(maybe a shadetree here and there).i have a few different gears that i start with.get on the freeway and pace yourself from mile marker to mile marker and look at the odometer.if the odometer is slow you need to speed up the gear by going with a gear with more teeth.if it is to fast you go down a few teeth on the gear.it's experimental but you can get there.
Old Jan 17, 2007 | 06:17 AM
tuff308's Avatar
ok will do, whenthe speedo reads100KMH (60MPH)i am actually doing 80KPH (49.5MPH) i tested this way with another vehicle, so if i go down in teeth it should make it better
Old Jan 17, 2007 | 12:02 PM
bowtieguy's Avatar
July 2009 ROTM
correct.do 60 from mile post to mile post,if your slow use a smaller gear,if your fast use a bigger gear.
Old Jan 19, 2007 | 09:57 PM
hotrodguy1986's Avatar
go to www.tciauto.com they have all the gears you need and a formula all you have to do is call them with the tooth count of your gear, tire size, and gear ratio and they will tell you just what you need and it will be exact. i just did that last week found out the gears i needed and picked them up from my local chevy dealer
Old Jan 19, 2007 | 09:58 PM
here is the exact location of your gears http://www.tciauto.com/Products/Comp...eter_gears.asp
78 on my plate
Oct 2, 2011 02:11 PM
wiseguy
Jan 10, 2011 05:30 PM
shnormo
Oct 16, 2006 11:56 PM
mike86rs
Jun 12, 2006 09:15 AM
