Shifting Troubles
Old Jun 24, 2008 | 03:38 PM
moeboy's Avatar
Default Shifting Troubles
So I just had the driveshaft replaced on my '95 3.4L Camaro.
When I got it back from the shop I had a hard time getting it into gear, i really had to slam it. Then later after work, I couldn't get it into gear at all for quite some time. I have since found out that when I first start up the car it won't go into any gear, but if I let it just sit and idle for about 5-10 mins I can get it to go, not easily, but its better than nothing.
I originally just figured I somehow ruined the clutch, but now I am thinking it maybe something else, since it seems to shift Ok sometimes after its been warmed up. Any Ideas? I had been driving with a pretty bad driveshaft for a few days, so I am wondering if that may have affected something?
I may just end up taking it back to the shop, but I figured I would ask around here first.
Old Jun 25, 2008 | 07:28 PM
Saint_Ali's Avatar
Default RE: Shifting Troubles
the drive shaft doesnt have anything to do with shifting its just what gets the vehicle to move, sounds like it could be the clutch or flywheel ever its hard to say
Old Jun 26, 2008 | 11:11 AM
bluovlh8er's Avatar
sure everything is lined up right???
Old Jun 26, 2008 | 06:44 PM
t9ojetpilot's Avatar
[&:] sounds more like a clutch master or slave cylinder problem id check these areas first kurt
Old Jul 3, 2008 | 02:38 AM
moeboy's Avatar
Yep, sure enough there was a leak in the slave cylinder. Thanks Guys
DacMan
82-92 V8 Tech
Aug 11, 2009 07:27 AM
DacMan
Aug 9, 2009 06:25 AM
tipdrip215
Dec 26, 2008 04:34 PM
nick
82-92 V8 Tech
Sep 13, 2007 01:21 PM
