Setting Timing
Old Jul 6, 2010 | 04:36 PM
white85camaro's Avatar
Default Setting Timing
Everytime I have my car running and switch the ignition off, the my car wants to keep running. I assume it's something to do with the timing. I don't exactly know what I need to do to set the timing. If someone could let me know the steps to do so that'd be great. Thanks!
Old Jul 9, 2010 | 10:20 PM
osduck5's Avatar
Is the throttle closing all the way when you turn it off? Is the engine temp normal or is it running a little on the hot side. Carbon builds up and that along with a good hot plug will allow the engine to continue to run even though the key is turned to the off position.
Old Jul 15, 2010 | 03:22 AM
It's running at a normal temp. I'll have to check on that throttle, it doesn't keep going if the cars not warmed up, but as soon as it gets warm it just keeps going.
palmers68
May 24, 2013 02:13 PM
ScottD
Mar 18, 2010 12:36 AM
uzl442
Jun 18, 2009 10:40 PM
sleephero92
82-92 V8 Tech
Mar 13, 2009 03:24 PM
sewerrat
82-92 V6 Tech
Sep 23, 2007 02:48 AM
