Running Hot
do you have eletric fans or manual? coolant level ok? any leaks from freeze plugs? you will have no heat if you by pass the core.. What thermostat are you running 180 or 190. When it overheats try turning the heat on, it will take some heat off the engine then turn the ac on it will automatically turn the electric fan on the secondary fan..
orlando_trudeau@yahoo.com
06-16-2009 12:35 PM
