Running hot?
Old Sep 6, 2011 | 04:43 PM
Virmagicus's Avatar
Default Running hot?
I noticed soon after i purchased my 95 if i was sitting at idle the temp gauge would go up about 3/4 on the gauge before the e-fan would kick on. The e-fan would bring the temp about 1/2 on the gauge and then shut off. I have no problems while driving as it only gets to about 1/4 up on the gauge which i would assume is about normal. It will stay the same if i am driving (outside temp 80-100) Do you guys have the same fluctuation when stopped with a 195 stat?
Old Sep 6, 2011 | 05:49 PM
buck658's Avatar
yup thats what mine does and never over heats so id say its fine
Old Sep 6, 2011 | 08:39 PM
Virmagicus's Avatar
Sounds ok then. I'm not sure why the motor would get near the 240 range before the fan would kick on though. Is it a one speed e-fan?
Old Sep 6, 2011 | 09:06 PM
buck658's Avatar
i couldnt tell you on that one, all i can say is if it aint broke then dont worry about it. just keep an eye on it and if you feel that uncomfortable with it get a lower thermostat or put ur fan on a switch. like i said ive had no problems with it this far..maybe someone else has some better input on this than me tho
Old Sep 6, 2011 | 11:20 PM
305_camaro's Avatar
March 2012 Ride of the Month
thats where it should run, i just changed every possible thing on my coolant system and it does the same thing...my 88 did the same thing too
Old Sep 7, 2011 | 12:48 AM
Virmagicus's Avatar
Nice. I was thinking something may be wrong. Still wondering about the fan speeds though. I'll see what i can find.
chevyguyjay
May 13, 2010 09:33 PM
Foxracing254
Oct 1, 2009 11:32 PM
orlando_trudeau@yahoo.com
Jun 16, 2009 12:35 PM
jake z28
Dec 1, 2008 05:36 PM
1badroc
Jan 24, 2005 02:55 PM
