Roll Cage
#22
If you want give me your bore size, head gasket thickness and bore, head chamber size, block deck height(9.025 stock), piston volume +- if they are dished they may be greater than 8cc you gave, I will calculate it for you.
His calculator is real close to mine though(I found it after the post).
#27
Sorry I messed up used the wrong stroke should have been 12.5 @.025 deck/13.5 @0 deck depends on head gasket thinkness, ring lands, true chamber volume. Again sorry about that. GRIFF
#29
The expandable foam is a great idea. The 230's are too big a runner for a 383, Won't make any power below 6000RPM, too much air tumbling and not enough airspeed. VP C16 is the best fuel out there for a Rael high comprecssion engine, massive amount of hydrocarbons slowing the burn rate. Hope this helps.
