which relay is for the engine fan
Old Jun 12, 2006 | 10:39 PM
bbowler86's Avatar
Default which relay is for the engine fan
Hello, I have a 95 V6 3.4 camaro, completely stock, I am trying to troubleshoot why my radiator fan is not coming on, there are 4 relays in there on the left 3 are the same and one is different and there is another on the right side that are the same as the other 3. Any help identifying which relay is which would be a great help.
Old Jun 13, 2006 | 01:54 AM
Default RE: which relay is for the engine fan
If the car came with one fan, there is only one relay involved. If it came with 2 fans,thre are 3 relays involved. Should be marked coolant fan . By the way, if the fan/s go/es on when the AC is turned on, the relay/s is/are good, and you may have issues with the ECT sensor.
Old Jun 13, 2006 | 03:05 AM
bbowler86's Avatar
thanks pete, however the fans do not come on when i turn on the AC, I can't find any identifying marks on or around them and it doesnt have anything about the interior fuse block in the owner's manuel, does anyone know where i could find or know what the stock setup for the interior fuse block would be?
also if anyone thinks it would help i could upload a picture of it
thanks
Old Aug 17, 2006 | 03:13 PM
Lifesaver's Avatar
Did you ever figure this out? I'd like to know too...
Graphite07
Apr 16, 2010 12:28 AM
greenarrow
Dec 29, 2008 12:18 AM
JDOBBS2
Oct 30, 2008 06:07 PM
metallifuk
May 7, 2006 04:34 PM
