fan relay help
Old Apr 15, 2010 | 02:41 PM
Graphite07's Avatar
Default fan relay help
okay i notice my electric fan is not coming on. where can i find the relay for it? or how to test the fan with out removing it from the car?? i seen a plug on the passanger side by the air cleaner.it looks like the wires lead to the electric fan? is that plug related to the fan to test it?
any help thanks.
Old Apr 15, 2010 | 07:07 PM
carguy68ssrs's Avatar
What year car and when is it not coming on?If you have air conditioning it should come on when you turn on the air (if it works, the air that is). Normally the fan is set to come on at like 210* which is hot.
Old Apr 15, 2010 | 09:19 PM
Graphite07's Avatar
1990 i do not think it comes on at all. A/C does not work and my temps get kind of high. i should hear it kick on when the temps gets to the middle line.
Old Apr 16, 2010 | 12:28 AM
You could just disconnect the fan plug and jump it straight to the battery to see if the fan works. the plug is right on the fan
myk3
Jul 15, 2009 12:24 PM
greenarrow
Dec 29, 2008 12:18 AM
camaro girl
Mar 19, 2007 07:28 PM
metallifuk
May 7, 2006 04:34 PM
