Rear Window Defroster
Have a 2002 V-6. The rear window defrost will turn on for about two minutes then shut off. If I push the button to turn it back on, can hear clicking but the light does not come back on; also does not turn on the defroster. Not sure if this is a broken timer or switch. It does heat up for the a brief period. Have tried to look up the timer, but cannot find the part anywhere. Curious if anyone else has come across this problem.
Thanks,
JD
Thanks,
JD
Hey - Cammy started doing the same thing your describing..! Dunno why she started it, sometimes mine stays on but usually it decides to turn off on me like yours.. I can usually just keep driving for a while though, try it again, and it turns on for a while again. I dunno...
lamppost
09-02-2010 08:59 PM
