Rear end humming
Ok guys, today i had a set of 373 gears installed in my 2000 SS camaro auto, it has 53k miles. But i went to pick it up and i noticed down the road that it was making a humming noise on acceleration and coming to a stop. I do know that the ring and pinion was used but not in bad shape at all, my friend that did the install has been building and working on cars over 20 years said he's used gears over and over on track cars that were worse and never had issues, but he did tell me that the bearing and shim kit i bought from the transparts warehouse had the wrong shims, he dug up some old ones he had and they fit fine,everything else was correct except the shims. What could the possible problem be??? And how bad can it be????? Any help or pointers would be greatly appreciated.
I would venture a guess and say the gear set was made by Richmond gear. They are know to whine due to the cut of the gear teeth (used for racing). Now that may why they were sold and in good condition. Nothing wrong with the install just the gears in my opinion.
could be a shim issue as well. but if he knows what he is doing, id let him know first. then if something does go wrong, you can hold him up to fixing it. if anything, run it a thousand miles, then pull the cover and inspect the wear
Well we pulled it apart again today, put some different shims eveything went back in ok it seemed to hit right in the middle, put it all back together and nothing. Bastard is still howling away lol. The only thing he could think was that maybe the gears being used sitting for at least a year and a half the way they sat in the box may have made the teeth warp or something. Well it ran fine all the way home sob really screams now but dang that whining is so AGGRAVATING.
then try running another set of gears. i was taught though to set the tooth pattern to the bottom 1/3 so that when the iron flexes from heat and load, its an even contact.
also, in your dash, you will see some ***** and buttons. the upper left ****, turn it clockwise until the sound goes away
Setting up gears is A LOT more intricate than just throwing some shims in there. Start from scratch with a new master install kit and the correct tools. Properly set pinion bearing preload and backlash, and properly shim the gears. Humming is not normal, and the fact that it got louder the second time confirms this.
