ratchet noise in trans but only in 5th gear
Old Apr 10, 2010 | 09:38 PM
Freshcamaro's Avatar
Default ratchet noise in trans but only in 5th gear
k so i have a 95 3.4l with at 5 speed. itll drive fine in first through fourth but recently when im in fifth which is my overdrive gear i hear and feel this noise that sounds kinda like a ratchet turning.... any ideas of what this is????
Old Apr 11, 2010 | 05:33 PM
A broken tooth on 5th gear.
Old Apr 12, 2010 | 10:37 AM
ok so im guessin that means rebuild??? and is it ok to drive in that gear till i get the money to rebuild it???
Old Apr 12, 2010 | 01:10 PM
Just hope the broken piece does not get jammed between two gears, as you can wind up wit a broken transmission case.
Old Apr 12, 2010 | 04:55 PM
Don't use 5th gear. You are hoping the counter gear is not damaged. If it is you might find getting a used tranny is a lot cheaper. If your mechanic does not mind using used parts it may be ok.
You will know better once you get the cover off but cheapest way out might be a used tranny and have it gone thru with a bearing/sycro kit.
Old Apr 20, 2010 | 12:35 AM
k so i decided to rebuild it myself. any tips?
Old Apr 20, 2010 | 07:29 PM
Normally the biggest problem is all the special tools you will need. Step one will be disassembley and inspection of all the parts to see whats wrong. The other critical thing is figuring out why something failed. You may have a failed 5th gear but it may have failed because of too much or not enough clearance some place. Automatic transmission are complicated but standards are very unforgiving.
mikes68
Nov 26, 2012 08:30 PM
stenny
70-81 V8 Tech
Sep 14, 2012 06:39 PM
bd92rs
Feb 11, 2009 12:33 AM
zlek131
Dec 28, 2008 03:41 PM
lt1z28
Feb 7, 2008 10:40 AM
