problem when started
Old Sep 15, 2009 | 09:12 PM
kirks11's Avatar
Default problem when started
when i start my car in the morning it puts out a little smoke its (dark in color) it is there for half a second then it gone and never does it again, oil pressure is fine it dosent burn any off the level is the same when i filled it up. for some reason it does it when its been sittin for more then 10 or so hours....i go to class for five hours and it does not do it when i get out just in the morning..
Old Sep 15, 2009 | 09:25 PM
Bad valve stem seals. When the seals are in good condition and working properly, they prevent oil that's coated on the valve stems (under the valve covers) from running down. Worn, sloppy, hard, or cracked seals will let oil run down the valve stem and into the cylinder. You'll get more oil running down the longer the engine sits. Then you get your puff of blue smoke when you first start the car. If you're not experiencing any other engine problems, and no accumulated oil loss, then what you have is just a small nuisance....for now.
daveypantele
Nov 18, 2014 01:32 PM
Camaro Kid 1991
Dec 9, 2012 10:50 PM
burnt68
May 9, 2010 08:29 AM
80sfan
Jun 26, 2009 05:47 PM
whammer3024
Jan 20, 2009 03:54 PM
