power steering cooler
Old Jul 1, 2008 | 12:12 AM
MadMikeZ28's Avatar
Default RE: power steering cooler
Just hook the power steering lines up normal like and replace the radiator hose that was spliced into.
Old Jul 1, 2008 | 12:22 AM
cbr600rr's Avatar
The reason I beleive it is factory is that the car had one owner before me and they was elderly. I have searched on yahoo and found that the 02 5.7L did have a factory power steering cooler. This is the only thing I can figure it is with the power steering fluid running through it.
Old Jul 1, 2008 | 12:34 AM
MadMikeZ28's Avatar
Hmm well maybe it did. But a note about the elderly. They are always sticking some wierd **** on their cars.
Maybe you can still just delete that part. Hook the two power steering lines together and replace the radiator hose. At least it could work until you get that part fixed.
Old Jul 1, 2008 | 12:37 AM
cbr600rr's Avatar
Ok found something almost identical to this one on e-bay. Maybe it is an aftermarket part. After I hook the line back up normal how can I get the radiator cleaned out. I have flushed and flushed the radiator but its not coming out to easily.
Old Jul 1, 2008 | 12:42 AM
cbr600rr's Avatar
Never mind about the e-bay part it list it to be a genuine oem part. I'll check with dealer tommorow.
Old Jul 1, 2008 | 12:50 AM
MadMikeZ28's Avatar
I think to flush it out you will just have to run some of the cooling system flush though it. Maybe after a good flushing with a water hose. There may be some residule but it should not hurt anything.
Old Jul 1, 2008 | 12:56 AM
MadMikeZ28's Avatar
Another thought. Since it is power steering fluid getting in your coolant just leave that tube in the radiator hose and pull off the power steering lines. Hook them together and cap off the ends on that tube.
Old Jul 1, 2008 | 03:24 PM
cbr600rr's Avatar
This is a factory part and was offered as an option. It retails for $150. Just spliced ps hose together and put the cooler back in the radiator line ($2). Thanks for all your help.
Old Jul 1, 2008 | 03:55 PM
MadMikeZ28's Avatar
As an option that might be why I never saw one before on any of the late models I worked on.But you might want to spend another $1 and get some rubber caps for the Steering cooler ends on that part. If power steering fluid got into the coolant the coolant could get into the tube inside and leak from the opening. I would think rubber caps should be good enough as it may be a very small leak and there wont be a lot of pressure from coolant wanting to come out.
Old Jul 5, 2008 | 01:26 PM
  #20
t9ojetpilot's Avatar
looks more like an aftermarket part, but could be a gm performance or corvette part?? any numbers on it?? if its factory it will have casting part numbers on it
libertyforall1776
Jun 11, 2014 11:34 PM
timmyz28
Sep 28, 2011 01:48 AM
shane1617
May 22, 2011 08:35 PM
Jeepinallreds
Feb 6, 2010 09:04 PM
Steve91T
Jan 12, 2007 04:32 AM
