92 Camaro stalls when warm and stopped (while in gear)
Old Jun 30, 2008 | 06:10 PM
92ChevyMuscle's Avatar
Default 92 Camaro stalls when warm and stopped (while in gear)
92 camaro RS...305/TBI/Auto
Changed out the distributor this weekend because the other one was completely rusted out. The car starts beautifully and runs like a top but as soon as I stop at a light, my car wants to conk out and stall. If I shift to Park or Neautral while I'm stopped, it will not die. Vacuum line? Distributor?
Thanks for your help.
Brian
Old Jun 30, 2008 | 06:24 PM
Default RE: 92 Camaro stalls when warm and stopped (while in gear)
One more thing to add....there are no codes showing up. Status 12 means all clear.
Old Jun 30, 2008 | 10:42 PM
Saint_Ali's Avatar
did you have this problem with the old distributor ?
Old Jun 30, 2008 | 11:31 PM
MadMikeZ28's Avatar
^^ what he asked.
If it did not happen before then you need to go over what you had done. Or maybe you got a bad distributer. Did you get a rebuilt like a cardone or a POS accel????
Old Jul 3, 2008 | 01:41 PM
It did not happen before the new distributor but I did quite a bit before changing it out. I changed intake gaskets/TBI gaskets as well.
If it was the distributor, I would think the engine would run rough and have issues starting. It seems more vacuum line oriented...possibly EGR. I'd really like a picture of someone 92 RS to see where the vacuum lines are connected.
What do you think?
Old Jul 5, 2008 | 01:34 PM
t9ojetpilot's Avatar
need to check your work, id look closely at your vacuum lines and maybe check timing kurt
Old Jul 5, 2008 | 03:44 PM
Since you mentioned that you messed with the throttle body, did you connect the IAC valve back in? And if you messed with the IAC, like trying to move the pintle by hand, you could have damaged the little drive gear inside the valve.
anticypher0101
Mar 29, 2024 01:32 AM
CZimmer
May 15, 2012 06:49 AM
73hugger
Jan 19, 2012 04:32 PM
shinwolf14
Sep 29, 2010 12:39 AM
rocco6
May 29, 2009 08:27 PM
