PCV Valve Help
Old Jun 16, 2007 | 05:24 PM
94Red's Avatar
Default PCV Valve Help
My 1994 Camaro 3.4 six banger ,
For some reason i do not recall seeing a PCV on my valve covers, i have a K&N Intake on it, (Installed be4 it was mine) could it be possible that it was removed??? Also is it located on the left side of the motor (Passenger)?? if so then its not there and theres just a grommet with a hose going to the K&N. Thanks again your all a great help.
Old Jun 16, 2007 | 07:30 PM
t9ojetpilot's Avatar
Default RE: PCV Valve Help
[X(] according to the oem service manual the v6's pcv valve should be on the drivers side valve cover in the rear. the other hose going to your k&n induction tube is the breather for the crankcase (air goes into engine here and comes out through the pcv valve and back into the combustion side of the engine) the pcv and its possibly short hose will go into the intake manifold may be mostly hidden by intake manifold ( you'll have to forgive my vague location as its been a while since i took a peek at a v6 version) kurt
Old Jun 17, 2007 | 11:09 PM
94Red's Avatar
Thanks for that info Kurt...... I will have a lookfor it after work today i appreciate your helo.
EagleRex
Oct 5, 2009 04:14 AM
Labyrinth9
Mar 20, 2008 09:15 AM
79camaro505
Feb 22, 2008 08:02 PM
3.4CamaroCDOG
Feb 1, 2008 07:22 PM
