overheating! Again...
Old Jun 18, 2007 | 06:57 PM
LT1RUNNER's Avatar
Default overheating! Again...
I know we've covered this a thousand times! Overheating! I don't care for the f-body cooling set up. Not sure if pulling hot air passing below it the best way to draw air in to cool your radiator. Not to mention that you need this plastic piece below (air dam) to help direct air into your radiator. Now if anyone has looked up into the radiator from below you'll see the small area that the air dam has to draw air up in to. Would taking off the plastic piece inside that area allowing the air to come from the front of the car through the fog lights work better? Your thoughts. Fact or just opinion.
Old Jun 18, 2007 | 09:26 PM
microkid's Avatar
March 2011 ROTM
Technical User
Default RE: overheating! Again...
what gen is this, a 4th gen? my car used to overheat in winter until i repaired the air dam and installed the plastic peices in front of it that channel the air from the grille and the other peice underneth that is curved to create a low pressure area
Old Jun 19, 2007 | 02:52 PM
LT1RUNNER's Avatar
The 3rd and 4th gen are the same right? Air dam on the bottom to scoop the air up? I was talking about 4gen but you reminded me about the 3gen being the same design.
Old Jun 20, 2007 | 09:23 AM
microkid's Avatar
March 2011 ROTM
Technical User
its kinda the same setup, but is different parts. best bet is to take this to the 4th gen area.
southw2
67-69 V8 Tech
Jun 12, 2011 10:02 AM
greenmachine96
Mar 18, 2011 12:29 PM
boxeranders
Jun 25, 2009 01:05 AM
g.pelka
Jan 31, 2008 07:00 PM
ChevCam87
82-92 V8 Tech
Jan 11, 2008 11:46 AM
