orifice tube AC
Old May 28, 2007 | 01:13 PM
M.$tErNeR's Avatar
Default orifice tube AC
just bought a can of ac refridgerant and put it in.did nothing.talked 2 some people and they all suggested an orifice tube...sure enough i bought one and took out my old one which 2 my suprising was covered in metal shavings so im thinking this has 2 be it.i replace the orifice tube and load her up with 2 more cans of ac refridgerant but now its still not cold like it should be??? im pretty much lost.any suggestions???
Old May 28, 2007 | 01:20 PM
Default RE: orifice tube AC
The shavings could have come fro the compressor, not good. Also you opened the system, so it needs to be evacuated with a proper pump and all the air and moisture removed, The amount of refrigerant to be added is going to be more than 2 cans, 3 1/2 to 4 lbs most likely. Take the car to an AC shops and let the expert handle it.
Old May 29, 2007 | 07:19 PM
t9ojetpilot's Avatar
[X(] ditto z28pete youve got more problems than a can will fix. now that the system has been opened it will need repairs to fix the item which is donating the metal and then evacuated to remove the moisture. let those who have the tools and equipment do thier thing kurt
Old May 29, 2007 | 09:40 PM
MadMikeZ28's Avatar
ORIGINAL: z28pete
[sm=exactly.gif]
Your One Poison
Sep 18, 2014 03:12 PM
2Z's
Jun 11, 2014 05:38 PM
PCweber
May 18, 2012 11:37 AM
bigtobyz28
Jun 1, 2011 08:56 PM
jbe123
Sep 7, 2007 12:40 AM
