Opti spark
Old Jan 13, 2007 | 07:02 PM
nash211's Avatar
Default Opti spark
Has anyone replaced one of these. I recently did and since I repaced the opti spark it will not start. I have contacted my local dealership told him what I have done so far and he suggested to change the plugs. I did check the oil and I do have approximately one quart of gas in the oil pan from trying to start the engine. All it does is goes poof poof etc, occassionally it backfires.
I have a 1995 trans am with a 5.7 litre engine, I installed a accel opti spark. I have changed the coil, plug wires, ICM module. There isa smell of gas, it is a pain to take out all the plugs and re install them. options anyone. Yes I amsure the opti spark is in correctly, it slid right in, not real gap between it and the block when pushed in. It tightened without any problem.
Suggestions
nash
Old Jan 14, 2007 | 02:07 PM
Default RE: Opti spark
If the car worked before you molested it, you either have bad parts, or something went in there wrong. Make sure the drive pin on the cam engaged the opti, it can go in without engaging.
Old Jan 15, 2007 | 05:42 PM
nash211's Avatar
Thanks fixed the problem rechecked the alignment of the dowel pin, works fine now.
nash
hyozanryu
Jun 15, 2013 06:43 PM
bd92rs
Sep 26, 2011 11:17 AM
camarorz28
Jul 25, 2008 10:56 AM
ufnwish
Oct 8, 2006 06:38 PM
kwest
Jun 13, 2006 09:03 PM
