Oil Sender
After installing a 1973 BB in My 79 Z I find the headers burn the plastic tube to the oil inst. Is there a place on this block wher I can connect unit that will clear headers?. Pesently attached above oil filter. Thanx larry
I used auto meter copper line and ran it up the front of the block and tucked under the valve cover. it doesn't look bad as long as you keep it close to the block. I used the front of the block.
