Oil Pressure Sender
Old Dec 18, 2008 | 01:02 PM
m.saum's Avatar
Default Oil Pressure Sender
Back story: Two days back, my tensioner pulley shatters, and my serpentine belt gets stripped to about half its regular thickness. I replace the pulley and belt, but it turns out that as the stripped piece was spinning, it hit my oil pressure sender. So now I have the plastic tubing of the sender, but the threaded part is still in the block.
Suggestions on getting it out so i can put a new sender in?
Old Dec 18, 2008 | 02:09 PM
Redneck97's Avatar
Default RE: Oil Pressure Sender
sounds like your going to have to make a trip to a machine shop.[:'(]
Old Dec 18, 2008 | 02:19 PM
m.saum's Avatar
The entire thing is plastic, i'm considering "notching" two small slots on the ring, and using a quarter to turn it out. I'll have to see if i can get it to work when I get home
Old Dec 19, 2008 | 09:21 PM
Chappie99's Avatar
that doesnt matter. The place to put the wrench is at the base of the sending unit. Just use a set of water pump plyers and turn the damn thing. You may even be able to take it off by hand.
Avery
Sep 3, 2013 11:10 PM
FSTKMARO
Dec 6, 2010 09:17 PM
TheWanderer
Sep 8, 2007 07:42 PM
Shmack2004
Jun 1, 2007 09:27 PM
super sport
Jan 8, 2007 05:32 PM
