thermostat?
Old Dec 19, 2008 | 08:15 PM
isaac11's Avatar
Default thermostat?
what does a 160* thermostat do?
like how does it help?
Old Dec 19, 2008 | 08:29 PM
Saint_Ali's Avatar
Default RE: thermostat?
it opens sooner, letting coolant flow faster.It usually will help lower your running temps.
Old Dec 19, 2008 | 08:31 PM
isaac11's Avatar
so does that mean like add horsepower?
Old Dec 19, 2008 | 08:36 PM
Saint_Ali's Avatar
no it has no effect on performance besides letting your car run cooler, it will not add any horsepower.
Old Dec 19, 2008 | 08:37 PM
MusicMan's Avatar
The Jazz Man
Adds squat, except fouled plugs and no heat. But if your tuned for it, then it helps. The 3.8's love to run at about 190ish degrees.
Old Dec 19, 2008 | 08:39 PM
isaac11's Avatar
oh so it really dosen't help
Old Dec 19, 2008 | 08:43 PM
Saint_Ali's Avatar
yes it does help, as musicman said if you get it tuned with the computer so the fans come on at the same time.It has no effect on fouled plugs.But he is right a car runs best between 190-210 degrees, but even if the thermostat opens at 160 and the fans come on at the same time your car still wont be exactly at 160, its still going to be around 180-200.
Old Dec 19, 2008 | 08:44 PM
isaac11's Avatar
so it just kinda protects your engine
Old Dec 19, 2008 | 08:46 PM
Saint_Ali's Avatar
yes so it lowers your chances of overheating, if youre looking for more power, look at exhaust,gears,intake,etc
MusicMan's Avatar
The Jazz Man
Here's what you do. Don't get it unless you have hp tuners, or a custom pcm tune from pcm for less. Problem solved. Otherwise you going to run rich, and that = not good.
