Oil Pressure & Water Temperature Problem
Old Aug 30, 2007 | 08:20 PM
73 T Top's Avatar
Default Oil Pressure & Water Temperature Problem
I rebuilt a 305 out of a 1978 camaro and i put it into my boat not long ago. Recently for some my oil temperature gauge has been pointing all the way right. It does it even when i turn the key on with the engine not running. Its1 quart low on oil.What could the problem be?
Also, when i turn the key on the temperature gauge goes all the way over but then drops down to about the middle when the engine is off. Currently it doesnt have a thermostat in it.
Maybe bad wiring for both the temp and oil pressure?
Old Aug 30, 2007 | 08:50 PM
Chappie99's Avatar
Default RE: Oil Pressure & Water Temperature Problem
sounds like a bad ground. A faulty ground will cause guages to stay pegged to the right.
Old Aug 31, 2007 | 01:26 AM
73 T Top's Avatar
ok thanks alot, i think i might even know the ground wire thats causing the problem
Volcente
May 15, 2012 08:28 AM
H2C
Mar 27, 2012 09:09 PM
wildcatk23
Jan 28, 2011 04:32 PM
Saint_Ali
Jun 18, 2006 09:23 PM
