Oil leek from hell
Old Feb 9, 2007 | 11:38 PM
BruteForcez28's Avatar
Default Oil leek from hell
I have a 95 Z28 and its got a bad leek comming from the front main seal. I replaced the seal and it tore the seal again. anyone else with this problem or know how to fix it?
Old Feb 9, 2007 | 11:48 PM
ghotachevy's Avatar
Default RE: Oil leek from hell
did u lube balancer up good when u put it back on
Old Feb 10, 2007 | 01:27 AM
MadMikeZ28's Avatar
Did your balancer have a groove in it? Did you notice any end play in the crank?
Old Feb 17, 2007 | 12:56 AM
Its a LT1 motor. there is no grove int the balancer. I lubed the seal real good befor install. still cant figure it out.
Old Feb 17, 2007 | 02:06 AM
MadMikeZ28's Avatar
I asked about the groove because believe it or not that rubber seal can wear a groove in the steel balancer. Are you positive it is coming out of the seal? No movement in the crank?
Old Feb 17, 2007 | 01:10 PM
ghotachevy's Avatar
timing chains have slapped the cover and put an holein ittoo if this might pertain
Old Feb 27, 2008 | 07:09 PM
95Camaroz28beast's Avatar
Is the front main seal a pretty common spot for an oil leak because I'm having the same problemon my 95 Z28 LT1. I haven't attempted to fix it because it leaks so bad I can't really pin point where the oil is really leaking from, but if the front main seal is a pretty common spot for an oil leak then i'll try and replace it. If anybody can help me I'd greatly appreciate it.
3.4_V6_Maroboy
Nov 19, 2009 10:36 AM
th3po1son
Dec 18, 2007 06:48 PM
koolme88
Apr 25, 2006 02:36 PM
