oil filters
Old Jun 29, 2005 | 06:05 PM
berlinettadave's Avatar
Default oil filters
i'm having trouble getting the oil filter off my '80 berlinetta and wondered if anyone knows any tricks for that
Old Aug 10, 2005 | 02:00 PM
Default RE: oil filters
What are u using to get it off? Try a filter wrench that is the proper size for your filter, it should have the same flat spots as the end of the filter & use a 3/8" ratchet to turn it. Last resort is to get a large screwdriver and stick it right through both sides of the filter and then twist the filter off. I don't like this last option because the filter can tear and then it will be a real bear to get it off. Good luck. Don't make it too tight when you put it back on (hand tight only + 1/4 turn with a wrench).
michaelross
Nov 9, 2013 06:56 AM
washtubman
82-92 V8 Tech
Apr 25, 2010 06:55 PM
thechink09
70-81 V8 Tech
Dec 19, 2009 01:57 PM
