no heat
Old Dec 18, 2008 | 11:27 AM
9camaro5's Avatar
Default no heat
hey guys i have a 95 camaro, the 3.8l v6
i get about 5 minutes of semi-warm heat blowing but after that, it just blows cold, can anybody tell me how to digure out if it could be the thermostat or the heater core?
any input would be greatly appreciated
thanks
-steve
Old Dec 18, 2008 | 12:57 PM
Default RE: no heat
Have you checked your coolant level? If it's low, it will affect your heat.
If your thermostat is bad (stuck open) you will notice it taking forever for your temp gauge to climb.
If the thermostat is stuck closed, your engine will heat up...and beyond.
Otherwise, your heater core could be clogged, or your controls aren't working properly to either let the coolant flow through the core, or not opening your doors under the dash.
Old Dec 18, 2008 | 02:22 PM
9camaro5's Avatar
Default RE: no heat
yes, my coolant is low, the temp gauge is working normally and doesnt seem to heat up too much
also, recently noticed i smell anti-freeze while the fan is blowing, tell-tale sign of heater core?
Old Dec 18, 2008 | 02:53 PM
Default RE: no heat
Yep, and that would also explain why the coolant is low.
When my core went, I was also getting steam coming out of the vents.
She blew out fast, and the inside filled up with smoke/steam.
Road-side emergency heater core bypass! Good thing I always carry tools.
c4maro
Feb 10, 2011 08:21 PM
92RS FTW
82-92 V8 Tech
14
Nov 26, 2010 07:37 AM
burning camaro
Nov 9, 2010 06:15 PM
sl1foru
Nov 10, 2007 10:16 AM
FullThrottleChick
Dec 6, 2005 09:59 AM
