New owner, just looking for tips
Old Feb 5, 2007 | 12:42 PM
squisher's Avatar
Default New owner, just looking for tips
I just picked up a '98 Camaro v6 5spd this weekend. It's got a couple of cosmetic things, but nothing beyond what I would expect on 81000 miles.
Just from driving it around this weekend, I'm noticing that the temp guage has buried itself behind a piece of trim in the cluster, I will dig into that later this week, I should be able to take the dash far enough apart to free it up.
I am also noticing a clunking type noise from the rear when I go around slow but sharp turns (parking, turning into my driveway, etc). Any tips on what could be there? I don't feel the suspension moving like it shouldn't, although I question how good the shocks are.
I've seen at least one recommendation for KYB AGX shocks/struts. I've got the KYB GR2's on my Fiero and they seem pretty good, so no problem with the brand there. I'm guessing I should also look into replacing the strut mounts at the same time. Probably wouldn't hurt to tackle the bushings and at least check balljoints/tie-rod ends while I've got things apart as well.
Are there any other little details that I should look for, or watch for?
Old Feb 5, 2007 | 10:18 PM
79maroman's Avatar
Default RE: New owner, just looking for tips
i would guess that the clunking noise is your u-joints.
Old Feb 6, 2007 | 11:57 AM
squisher's Avatar
Hmm. I also had that thought, but wouldn't that noise occur every time I change the load direction on the drivetrain? Like going from on throttle to off, just to give the driveline a small shock, I would expect that loose u-joints would clunk there also. I'll definitely check them when I get under the car, but with only 81650 for mileage, u-joints is not something I would expect.
Thanks.
Old Feb 10, 2007 | 05:09 PM
91RSADDISON's Avatar
i would upgrade to polyurethane bushings in the front and back. it helps alot with the flex and with noises because my 91 rs would make noises like that and i replaced all the end links and torque bar. every bushing it polyurethane and it doesnt make a sound.
Old Feb 11, 2007 | 11:50 AM
squisher's Avatar
ORIGINAL: 91RSADDISON
Sounds like a good plan for when the weather warms up. For now I'll just drive it.
MastaGunZ
May 29, 2012 02:54 PM
WindyCitySuperSport
Oct 31, 2011 06:48 PM
9434V6
Aug 18, 2011 07:53 PM
Phalen123
Mar 28, 2011 01:45 PM
bobarian91
Jan 22, 2009 04:57 PM
