need help quick headlights
Old Aug 26, 2011 | 07:03 PM
kirks11's Avatar
Default need help quick headlights
on my car i had hids and i noticed the driver side was flickering like a strobe light. today i put my old stock bulbs in and the hi beam is on with the low beam and both are dim i pulled the high beam fuze and lost both lights im getting good power to each i checked all fuzes and circuit breakers i couldnt see any wires touching each other.... any ideas im wanting to go run tonight but i cant with one head light thanks for the help in advance
Old Aug 26, 2011 | 09:53 PM
Bad ground connection is a possibility. Check voltage with lights on by back probing the wires at the connector.
Old Aug 27, 2011 | 05:49 PM
kirks11's Avatar
Thumbs up
found it i checked all the voltage ecerything seemed fine then i moved a hose and found a black box with alot of grounds goin to it. i tightened it an was good
Cliff123454321
Mar 18, 2012 09:22 AM
AV95Z
Feb 17, 2008 02:30 PM
sooperdewd
Jan 3, 2007 06:25 PM
