looking for a new cam advise please
Old Oct 11, 2011 | 10:46 PM
endo's Avatar
Default looking for a new cam advise please
my car does not have the right sound. I want more of a camed sound. what would you guys suggest? This is a DD with a 5 speed and i want to make a little more power.
see below for engine specs.
Block
350
Bored .040 over
Stock crank and rods
Stock style dished pistons
heads
casting # 3927186
date code is H278 - August 27, 1968
intake 2.02" exhaust 1.6" chamber CC 63.305
a little porting done to them.
stainless 2.02 in manley intake valves
metal viton seals
3/8 rocker stud
Cam
Comp Cam Part #: 12-210-2
Grind #: 268H
RPM-Range:1500 to 5500
Lobe-Center Angle: 110
Duration: Intake 268 Exhaust 268
Duration at 050 inch Lift: 218 int./218 exh
Valve Lift with Factory Rocker Arm Ratio: 0.454 int./0.454 exh.
Rockers
COMP Cams Magnum Rocker Arm Kit
Manufacturer's Part Number RP1412-16
Rocker Arm Ratio: 1.52
Rocker Arm Style: Roller tip
Stud Size: 3/8 in.
Notes: Kit includes pushrods.
Intake
Edelbrock Performer RPM Air-Gap Intake Manifold
Manufacturer's Part Number: 7501
Intake Style: Dual plane
Basic Operating RPM Range: 1,500-6,500
1” spacer
Carburetor
Edelbrock: 1406
Number of Barrels: 4
Carburetor Flange: Square bore
CFM: 600
HEI Distributor
MSD Street Fire HEI 8362
Old Oct 12, 2011 | 11:39 AM
greenmachine96's Avatar
What's your compression ratio? and you are talking about the car in your sig description right? If your over 9:1 comp. then this should sound pretty good..... 08-601-8 - Thumpr
I would suggest buying 1.6 rocker arms and get the cam and lifter kit. should be around 450 bucks then add whatever you spend on rocker arms. Jegs has some steel rollers for around 100 bucks a set.
Here's a video of a milder version of that cam...
http://www.youtube.com/watch?v=tKOvjClqC30
Old Oct 12, 2011 | 10:19 PM
endo's Avatar
1969 Camaro SS For Sale! - Comp Cams ***** Thumpr Cam - Idle In Garage - YouTube
I hadn't realized that i didn't update my sig. I listed out the current specs up above though. Its a 350.
I need to verify my compression but i already have flat Hyd lifters. I was thinking the 12-600-4 - thumpr. and possibly switching to 1.6 rockers
Old Oct 14, 2011 | 07:46 PM
endo's Avatar
any other opinions on the thumpr cam
glensilver
Oct 3, 2010 08:26 AM
SixShooterCamaro
Jul 27, 2009 01:38 AM
kdm212
May 26, 2009 09:00 PM
CamaroSS1980
82-92 V8 Tech
Jul 10, 2008 11:54 PM
FunkyColdMedina
Jan 29, 2007 03:04 AM
