locked up motor???
Old May 15, 2007 | 03:37 PM
ghotachevy's Avatar
Default locked up motor???
started up went thru like two firing orders and now will barely turn over bad main bearing? [align=right][/align]
Old May 15, 2007 | 10:31 PM
MadMikeZ28's Avatar
Default RE: locked up motor???
Bad starter and/or battery
Old May 15, 2007 | 11:38 PM
ghotachevy's Avatar
both new yanked the motor bad bearing
Old May 22, 2007 | 02:53 PM
ghotachevy's Avatar
alright here is what i found at first glance alluminum everywhere
there are two pistons that have a tiny piece missin off the skirt and a crack what the **** caused this
Old May 23, 2007 | 10:40 AM
Who put the engine toghether? Was the engine spun by hand frst to see if it could turn easily?
Possibilities:
A lot of coolant or oil in combustion chamber, causing hydrolock
Pistons hitting the heads
Valves hitting pistons
Bad ring gap
Really bad ignition timing
Foreign stuff inside engine.
Old May 23, 2007 | 01:49 PM
ghotachevy's Avatar
i was to lazy to build so bought one from the advertiser that was just rebuilt ( half *** Obviously)
motor turned fine by hand
why is there just lil pieces off the bottom of the skirt and not cracks or anything at top
Old May 23, 2007 | 06:55 PM
ghotachevy's Avatar
well ripped the whole thing down spun a rod bearing on 8 and it looks like maybe the cam lobe knocked the piece of the two pistons
what did this guy do to this thing
Tomg303
Nov 19, 2012 06:10 PM
Fred
LS Series Tech
Oct 21, 2011 08:12 PM
Mesosneaky
Oct 25, 2010 07:27 PM
antknowsbest
Jul 9, 2010 11:40 PM
94z
Oct 28, 2008 05:08 PM
