leaking oil
Old Mar 3, 2011 | 04:21 PM
98ssconv's Avatar
Default leaking oil
I noticed some drops on my driveway took a look couldn't see any obvious place where it was leaking from. So ky question is what usually leaks on these motor wise. I'm 100% sure its oil. I just had the rear main replaced two months ago. It seems to be right above the trans any ideas??
Old Mar 4, 2011 | 09:05 AM
djs383's Avatar
If you just had that seal done, that is where I would start looking. What motor is it? if its a 2nd or 3rd gen, sometimes the oil pressure sending unit can leak and run down the block and it makes it tough to find.
Old Mar 8, 2011 | 12:47 AM
carguylt1's Avatar
check the back of the intake also or valve cover.
Old Mar 9, 2011 | 01:20 PM
98ssconv's Avatar
It ended up being the oil filter adapter easy fix!!
husker_camaro95
Nov 22, 2010 03:25 PM
My SilverJet
Jul 22, 2008 07:58 PM
bcharlton
Apr 14, 2008 05:05 PM
trishiepoo
Nov 3, 2007 06:54 PM
Mace587
Sep 18, 2006 12:20 AM
